peepsalot said:So if the back seat is rendered unusable, why not just remove the seats entirely? Just curious.
I still run local autocrosses in STX which requires a full interior.
lasermp5 said:Umm... idk if it's just me or what, but this link looks like a good example of how not to mount a harness. In a flip, spinal compression will ensue, and you'll either be paralyzed or dead. There is plenty of info on this around the forum, and net.
Someone asked if you can mount harnesses safely w/out getting a roll bar or cage etc... and yes you can, but you want to either have a harness bar, or have the harnesses mounted at no less than a 45* angle off your back. Idk if that makes sense or not to you, but just search it and you'll see what I mean. I too have looke into the autopower option and I'm still trying to decide between it and two other options: using a subaru wrx sparco harness bar in the p5, or making my own custom harness bar/roll bar. We'll see...
id have to completly agree on this stament. i use mine strictly for track but i love all the good staments in this tread. yes you should use much lager mounting platforms and they also want you to idealy have the mounts on two perpendicular surfaces anyway. oh and weld this stuff in too!! its when we crash at speed or not experianced or not. why do you where a helment. lets just say s*** happens guys and girls. if your doing it for a show car then who cares just slap anthing in there. but im in Mid West council that has a few pages on how there cadges must be made and instaled. anway i like my harnes with out roll bar my class dose not require it so its just extra weight. and i need that harness kinda skinny and i slide around alot in mine plus i have been in a bad crash with a tire wall and i was thanking god that i had it. or i would have had a stick shift up my u know what yeah i cant spellMallard said:I would have to disagree with this statement also. If you don't have a harness and you roll hard enough to compress the roof 3-4 inches (which judging by rollover crash pics of our cars that would be one hell of a force) you will be experincing quite a few g's at impact. With a harness your body stays put. With your stock 3 point belt your body is going to go in whatever direction it can to get out of that belt and if you hit something it will be at around that g force. So during a rollover these side forces would be tossing you around a lot more then in a 4 point harness.
Judging from rollover pics of our cars on the freeway, I feel safe enough wearing that harness at the track. Were I in an accident with a high enough g impact to collapse the roof enough to touch my helmet I probably wouldn't be tapdancing, harness or not. Is it ideal, no. Would I feel safe about using it in any car without a rollbar? No.
Rogue Pro5 said:is that diagram only for a roll cage? I have the Schroth 4pt harness, and it mounts to the rear seat where the stock seatbelt mounts (at the bottom). Is that a problem?
MiaTurbo said:Mallard,
In a frontal/side impact you would be "ok". but if you were to flip over, laser is correct, the angle of the belt would result in compression of the spine regardless of how much the roof caved in. You shouldn't have the shoulder belts more than 10* from your back angle.
http://www.simpsonraceproducts.com/safety/safety.aspx?page=restraint_info
only the shoulder belts release a little slack, it keeps you from submarineing in the harness. In case you don't know, unlike a 5 point harness, a 4 point harness has nothing to hold the belt around your waist. It's possible in a collision (if the shoulder straps push you down in the seat) that you'll slide under the bottom belt a bit, causing the lap belt to hold you across the stomach (that's bad). The slack that is allowed is only enough to keep the lap belt in your lap.MiaTurbo said:why would you want a belt that releases slack on impact?
