Rim weight
Its been reported that the 2004 - 2006 17 rims weigh 19.4lbs. The snowflake rims I'm not sure on.
Stolen from the other forums and I don't believe anyone has updated with 2008 info.
Note that there are 2 versions of 2004-2006 OEM 17" wheels.
Stock wheel & Tire info
All sizes:
Bolt Pattern - 5x114.3 (5x4.5)
Hub Bore - 67mm
Lug-nut pitch - 12mm 1.5
Updated by Bean
OEM Mazda3 15-inch:
Width - 6.0 inches
Offset - 52.5mm
Weight - please submit via PM
Tire size - P195/65/15 H-rated
2004-2006 OEM Mazda3 16-inch: (updated 4/9/07)
Width - 6.5 inches
Offset - 52.5mm
Weight - 18.4lbs
Wheel+Tire - 39.4 lbs with Toyo Proxes P205/55/16
2007 OEM Mazda3 16-inch: (updated 4/9/07)
[needs to be verified]
Width - 6.5 inches
Offset - 52.5mm
Weight - 18.4lbs
OEM Mazda3 17-inch:
Width - 6.5 inches
Offset - 52.5mm
Weight -
Wheel alone - 22lbs (thread unknown) or
19.4 lbs
Wheel+tire - 43.4 lbs
Tire size - P205/50/17
2007 OEM Mazda3 17-inch: (added 4/9/07)
Width - 6.5 inches
Offset - 52.5mm
Weight -
Wheel alone - 22.1lbs
Wheel+tire - 43.4 lbs with Goodyear RSA P205/50/17
