Rim Help Please!
Pattinjr2
2011 Mazda 2 Touring
i have 15x7 +36 motegi's which look similar to the first link and they fit perfect the ad says 12lbs which isnt bad but there is lighter wheels out there mine are 10lbs and with our cars as underpowered as they are the scrubbing weight off the wheels and tires is big time noticable..just my .02
To the OP, how low are you planning on going? Are you stock right now? Lowering springs? Coilovers?
15x7 +36 won't need any fender modifications unless you're running closer to 3.5" lower than stock and running some wide 205/50's.
Pretty much, if you want the least amount of stress possible with fitting the new wheels, stick with the 15x7's
