Rico's build thread.
I would like more pics of the front end please and thank you. :)
You should get a photo shoot together, man.
^ agreed ^
also, what are the specs on your wheels and what size spacers are you using? I'm trying to get a good idea of wheel width/wheel offset/spacer offset. I want to get my 7" +52 front wheels flush
as soon as I find out y the driver side sags and not the passenger side and get that fixed and give it a good clean I will with atleast my bros evo and dads 500+hp daily 4dr civic
^ agreed ^
specs are stock rx8 wheels specs. spacer i think its a 7mm bro had laying around at home that im using on the rear. ill look it up or ask him tho hold up.
EDIT yes ones on rear right now are 7mm. i think on a hard turn im rubbing so I think for the rear 5mm might do. then going to try the 7mm ones in the front and see what ill need or if thats good for the front.
So 18x8 RX-8 wheels(52.5mm offset) . You have 13mm more on the inside and outside of your wheels. You guys know of anyone that was flush with 1st gen MS3 wheels? 18x7 +52
Ms3 with the spacers
