Rico's build thread.
cool well my offer still stands they wont be like professional shots but theyll still be good though so lmk when your ready
Trying to decide bags or coils lol
Added the adjustable rear end links on today
bags- expenisve, but can drop when you want em. not that good of handling (compared to coilovers) and you have to have a compressor in the trunk.
coilovers-relatively cheap. (blown set on here for 200$) can fine tune your setup, better handling, and stiffer.
coilovers all the way,
You need to put the car on the ground and make adjustments to the sway bar links.
Take one side off. The. Lower the car. put the link back on, then adjust the other side.
So take off link, lower car with it not on and when car is back down put it on at that height?
Yes. Disconnect one side, lower car, reconnect it while on the ground, and adjust the other on while on the ground also. Sway bars need to be adjusted with the suspension loaded.
I really like your build, and your wheels! makes your p5 look so unique.. in my book you define the overall look of you car by the rims !
