Resuming Playback with 2014 CX-5 GT Tech Stereo and other issues
Let's hope they fix it. If you use the new nano with bluetooth, what happens if you plug it into the USB to charge? Does it still stream via bluetooth, or does it switch over to the USB control? Does it pause playback when using bluetooth when switching off the car?
I actually have not tried the bluetooth on the new Nano. But when I used my iPhone 4S, it switched from playing through bluetooth to the USB (as "iPod"). So for the Nano, best way is to plug it to the other 12V power in the center console for charging, then use the bluetooth to connect to the head unit.
So it doesn't resume when using an ipod, but what about when playing an mp3 off of a usb thumb drive? I believe that HandA said this worked for the 13 - just want to be sure it does not on the 14? That may be the info that needs to get to Mazda on these complaints.
Doesn't resume with a USB drive, either on the 2014 GT w/Tech. In my case, I have tried several different ways of organizing files/folders on the drive - none worked. My files were mostly AAC, with some MP3.
Did you get a reply back from Mazda or your dealer?
My 2013 resumes at the same song every time with my ipod Nano. I don't know what generation my Nano is but it is the one with the color screen and was purchased last year.
I got an e-mail from Mazda - scroll up to my earlier post to see what they said. The dealer gave me a phone # to the Mazda bluetooth hotline. I called and they were useless. Next, the dealer has given me names and phone #'s of two guys in their local service department. I haven't called them yet.
This is what I got from Mazda when I emailed them. Pretty much the same:
"Thank you for contacting Mazda regarding your 2014 MAZDA CX-5. We are sorry to hear that you have this concern. It is normal operation for the playback to start at the beginning. What you can do for this concern is contact your local dealer for inspection to ensure system is operating correctly. "
How can that be normal operation for 2014 when for the 2013 it is not like that? Hopefully they figure a patch/firmware update.
My iPhone resumes when connected through Bluetooth. If I want to change playlists, I'll hold the Home button for a few seconds and use voice activation. "Play Playlist Chill". Here's to hoping Mazda puts a Siri button into future Mazdas in the near future. My 3 doesn't have a USB port so I can't comment there. I prefer Bluetooth since for short drives, I don't have to plug in my iPhone, I don't even have to remove it from my pocket.
My iPhone 4S resumes through bluetooth also, however, shuffle (and repeat) get disabled. If you are shuffling a playlist of songs, upon re-connecting, it will then continue that playlist in order. For me, this is a problem. If either the resume feature existed for USB or non-disabling of shuffle on bluetooth, then I could use either one of them and have a viable option for music playback besides AUX IN.
Just picked up my CX-9 yesterday (2013 Touring w/Tech package). My USB stick does not resume playback after turning off. I guarantee you this is a bug/oversight in the new software by the developers if this was something it had in the past. My 7 year old Kenwood head unit not only resumes play via the USB port after turning off, but even if I remove the USB stick and insert it again it remembers the position.
We need to get everyone to email Mazda about this. I plan on emailing them from several different email addresses.
Yes, I agree, this is a major oversight and has to be a software bug and not a hardware limitation. I would have pulled the trigger on the CX-9 if it hadn't been for this.
Yeah, can't say I regret my purchase because of it, but it is a slightly more than minor annoyance. I'm gonna try a few different things though to see if I can get it to work. I currently have all of the music files at least 2-3 folders in. I may try just putting all the MP3's in the root of the drive and see if that changes anything (I don't hold much optimism on that though).
I would have been OK with it starting over if it didn't take over a minute to read my iPod every time. Those two issues put together made it a no go for me considering the main reason I wanted to buy the 2013 model and trade in my 2008 CX-9 was for the better iPod integration!
I'm cheering for a solution. The enhancements to the 2013 CX-9 like mirror memory and auto door locks would have been a nice upgrade.
I just tried putting only a handful of MP3's in the root of the drive, and not only did it not resume playback in the correct spot, but it still took a good 30 seconds to load. I was using a 16GB drive, so not sure if that makes a difference. Was also wondering if I should try formatting it in something other than fat32.
Something obviously isn't right here and Mazda needs to be held accountable. I would take it back to the dealer but I know nothing would come of it.
I have a 32GB iPod nano and it loads pretty quickly (about 8-10 seconds) and always resumes playback at the same spot. I have all songs in one large playlist and I haven't tried anything else. No issues here.
2013 cx-5s don't have the issue being discussed. It's wierd that it worked fine in the 2013s and then they messed something up in the 2014 cx5 and 2013 cx9
Can someone with a '13 confirm if the usb port is always "hot" or if power is cut when the car is switched off? In the '14 the power is definitely cut. I will elaborate tomorrow with some testing results I did shortly after I got my car home.
As a followup from my post from last night, when I first got the car I tested several things. Here are a few things I tested:
1.) if the car is on, and you plug in a USB stick, playing will commence quickly, and does not seem to require a full read of the stick.
2.) If you turn the audio off and back on, the mp3 will resume in the same place.
3.) if you turn the audio off, and then turn off the car, and quickly restart it, then turn the audio back on, it will resume.
4.) if you turn on the electronics by pushing the start button without depressing the brake, have an MP3 start playing, then turn off the electronics, and turn it back on quickly (within 4-5 seconds) it will resume.
I need to make a real chart where I mark down exact specifics, but the gist of what I found was that the MP3 would resume when playing via USB, as long as the time that the power was off wasn't very long. The headunit would still do its "startup" where you would see the TomTom screen, but then audio would resume right away. If however the car was off for longer, then when you start up it does the long read of the USB device, where then it finally starts playing everything from the beginning again.
This is why I was curious about whether power goes to the USB port constantly on the 2013 vs 2014, because the head unit isn't having an issue with a quick power cycle, but rather a longer term power cycle. If it is something as simple as the port staying hot on the 13 and not on the 14, that is user resolvable.
I doubt it is this easy, but it is the first thing I would like to eliminate to answer this question.
Chris
Interesting findings Chris. I did notice that too with my 2013 CX-9 - if you stopped and started quickly, it did remember the last setting.
So what would entail making the USB "hot" all the time? Just moving to a different fuse or something? Would there be any battery drainage concerns with that?
