Starting to become a money pit...
Note, and note well, I bought this car at about 66k, it now has 92k. It was wrecked once by the previous (first) owner. I didn't know quite how bad until after my wreck. Turns out it was already on its second hood. I raced it for one season SCCA solo. It's completely stock (sorta). I drive... spirited. I'm no granny and I floor it pretty often, but I've never hit the rev-limiter. So yea, I've beat it a bit. So, onto the problems.
1. The clunk, even after the 5th round revised sway bar bushings upgrade.
2. Its a bear sometimes to get into 5th, synchros bout dead or something, I double-clutch anyway.
3. In the cold 1st is next to impossible, just until it warms up.
4. The stereo screen went full bright, unreadable. Got a new faceplate, no biggie.
5. Started misfiring in the second (from left) cylinder. Found out this was due to the damned rubber ends on the spark plug boots, that cylinders rubber end was cracked, disintegrating. $300 for new coil packs and wires, or 15c for a piece of electrical tape, your choice, I can't speak for new wires but the tape worked. Took a damned long time to fugger that out though.
6. Rubber in right motor mount got FUBARed, new mount from dealer wasn't horrendous
7. The trunk leak, water in left trunk side panel, sometimes spare tire well... still haven't quite fixed that. No rust yet, not much water, but still a definite annoyance.
8. So I get it paid off, and the next month, ****** cuts out in front of me, right front banged in. Not driveable. Insurance took it up the butt, damned near totalled. Being inexperienced, I knew not what a ride I was in for. Body shop took almost 3 months, cus of 'ordering delays'... But I was happy, looked almost good as new, new radiator, new fog light that I had busted beforehand. Stereo now does not play data disks like MP3 cds... grr
9. Months later, my dumb ass is cornering like im at the scca race again, let off throttle through an s-curve, backend lifts and kicks, I catch but overcorrect, and end up backed into a fence, with a 1ft tall concrete block caught under the front... This is where the real trouble begins. The fence only did cosmetic damage, the concrete block twisted the s*** out of the frame piece under the engine with the tranny mount. Had to have that replaced, and they had to replace the oil pan as well. I had a feeling this would spell doom. This wasn't cheap for my insurance either, they hate me by now... Also stereo doesn't play some normal cds...grr
10. New oil pan gasket leaks, I checked bolts, they weren't even hand tight... took it back.
11. Doom came knocking soon enough. It's been a few months, and then I'm in a parking lot about to shut off and the oil pressure light comes on. (Mutters curses...) Then this horrid knocking starts... I shut off, check oil, there is none...  Engine is essentially blown, It ran enough to get it on a trailer, then it was dead, the front crank seal and cam seal were blown, and I had severe knocking... So, time for a new engine. (I don't know for sure if this was due to beating or the wrecks or both)
12. New engine, new probs, car had 92k on it, engine had 66k. Got a real deal on the engine and install. No probs right after install, but then s*** started to go wrong. First a little coolant leak, fixed that with a new hose clamp.
13. Exhaust leak. The 90 off the first cat, where the springloaded bolts hold the flange gasket in. The holes for the springbolts on the 90 broke off (they are incredibley thin). This piece is Not sold aftermarket, and from the dealer its $211. Right now its rigged with coathangers, sounds like a hellspawn lawnmower with a rumble. I haven't yet made a decision whether to buy the replacement piece, wait for the backordered OBX header, or weld something up on the old b****.
14. This exhaust noise seems to have made the bolt for the tranny mount on the front come out...wtf
15. The sway bar links have hit the bucket, rear left fell off the wheel end... going up to the dealer with some anal lube.
16. Also after the first wreck, when I use the a/c and make left turns, water sprays all over passengers feet... kinda funny sometimes... mostly annoying and mold causing. I never use a/c anyway.
17. Reminds me that the fan started screeching at > 2 occasionally. Stops if you shut off and restart.
18. Dash brake light comes on/stays (with e brake completely down) on in hard cornering, sometimes just randomly, hasn't done that in months though.
So anyway, yea I'm not the brightest crayon all the time, but this car is getting weird on me.(scratch)
