Hi,
So I'm a soon-to-be proud owner of a 2008 Mazda 3 GT; I'm picking it up this Friday. It drove amazing, much more stable than my Protege and much less rust. I did go get it inspected as both the original owner and I noticed a spot on his driveway, but we the inspection revealed nothing. One issue that was noted was how I would have to replace the rear camber arms as they were worn out and slowly eating away at the rear tires.
Canadian Tire quoted me almost 800$ for the job, which sounds ridiculous to me. I'm here to ask how do-able it is. I can do small easy jobs, I change my own oil/spark plugs and have changed rear brakes and engine mounts before, but I'm really no mechanic. I've already found adjustable ones on corksport for 200$ and they come with instructions!
I'm pretty sure I'll need an alignment after the installation, but if I can install them myself, I can save a good 400$ or so.
So have any of you installed these before and how easy are they to change?
Thanks
The part:
http://www.corksport.com/corksport-rear-adjustable-camber-arms.html
The car:
Thanks
The part:
The car:
