My motor was eating coolant and had several other issues such as a leak at the turbo/ exhaust manifold joint, and some issues with a few motor mounts. So after taking the motor apart and fixing everything and putting it back together, minus the radiator and intercooler, I tried to fire it up to make sure it would run, but it would not start. upon testing the compression it was lacking. 30-60-0-60 was the numbers we got. since the motor was running fine before the head gasket was changed, we took it down to the head and took the head back to the machine shop. before we took it back we did the water test and the valves did appear to be leaking. of course the machine shop did complain about fixing it but the did eventually take it back. upon putting it back on again with a new head gasket and new head bolts and putting the engine back together again it still did not start. I will start compression testing tomorrow as it was quite late when I was done.
What I am wondering is is there anything that could cause the car to not start after having the head gasket replaced? it is acting like it does not have compression again but until I test it tomorrow I wouldn't know.
has anyone experienced this problem or have any ideas as to what else might be causing it.
