Removing the Battery Box installing the CS SRI+TIP
AGX-47
2012 Speed w/Tech
It seems like in order to get the battery box out of the car you need to remove the white plastic wiring harness that the ECU clips are connected to. Otherwise there is no clearance to get the box out. Thing is the Corksport instructions mentioned nothing about this, so how did everyone else do it? Am I missing something?
Pop the clip loose from the airbox, the harness should come loose for you.
-Derrick
