Removing rear light cover...
Manny Fresh
Mazda 3 GT GFX / Manual / Indigo Blue
So there's a dead fly inside my rear driver's side light casing...
How do I safely remove it to get rid of the fly?
I took a look at it, but wasn't too sure... I don't wanna crack or peel anything.
Thanks,
Manny
Thanks,
Manny
what the hell,lol, that should be a sealed unit so that water doesnt get in there and fog up the inside. that fly did some david copperfield s*** or sumthin????
That's what I thought too... water doesn't seem to get in, but magically a fly appeared in there.
Craziness.
Craziness.
fam says paint the whole light the color of car and make a happy face see through with the tail light and no one will be able to see fly. Make sure you dont paint the other side, just kidding,
My real recommendation is to remove the whole light (8mm nuts probably) unplug the bulbs, and bam! Instant whole for flies to fly out!(pun intended), make sure you put bulbs back in right whole as putting things in wrong holes would be bad in this case!
-FaM
in my old honda, i had a dead bee in there for years. still don't know how the hell it got in there. definately magic.
the tail light lens doesnt come off, its sealed from production, if you take it off youll be up a creek in most cases, just unbolt the light and once u take out the bulb you can remove the magical creature, or come to toledo and ill give it a go for 5 bucks!
