I am a newbie in this forum and in modding cars. I recently purchased a MP5 and love it. However I'd like to upgrade a little. It seems as though many people on this forum have done a lot of experimenting and modding and may be able to help.
1) I'd like an exhaust system that can be removed without welding or cutting when my car needs servicing or inspections/emissions? Most exhausts I've seen are welded at some point. Is this type of exhaust system available? The car warranty is important to me and i don't want to lose it over an exhaust. If possible I would like it to sound pretty quiet, but have a deep rumble at idle and in upper rpm. The small increase in horsepower would be great to. The way i envision this would be having the exhaust connected via bushings to underbody and bolted to the downpipe coming from exhaust manifold. When needed, run the car up on ramps and unbolt exhaust, remove from bushings and then reverse for stock exhaust. Is this possible??
2) Is straight piping best? eleminating the cats all together?
2) If possible what type exhaust system can do this and what type of modding is required? I don't want a really noisy weedwackier type sound. I would like a quieter rumble that increases as rpm increases.
3) If not possible can a muffler give this sound or something like it
4) And finally what effect will it have on the engine sensors and the ecu. If this is a problem what is needed to fix it?
Thanks for any advise or suggestions
Scott
Scott
