Remote Start for MS6
bobby0283
2006 Mazdaspeed6
I'm working on wiring in a remote start with a PATS3 keyless entry bypass and am having a bit of trouble. The wiring diagram that came with the kit was for an 05 Mazda 6, the guy told me it would be the same on an 06 MS6. Wrong... I have the main stuff wired into the main wiring harness under the steering column, but I can't find:
-The keyless entry module. Apparently on the 05 6 it was in the passenger side kick panel with blue wiring coming out.
-The wires for the doorpins and trunkpin
-The wire for the brake switch
-The correct wire for the parking lights. I found the light green/red stripe wires that were spot welded together, but when I wired into them, the parking lights are now constantly on when the car is on, no matter if I turn them off.
Anyone know where I can find a wiring diagram for an 06 MS6, or anyone have pictures of an install?
You should be able to find all of your wires using a standard DMM. If you don't have one, go and buy one, better yet take your car to a professional...
tech sheet for the 06:
12 Volts black/yel (40A), black (30A) + ignition harness
Second 12 Volts
Starter black/blue + ignition harness
Second Starter N/A
Ignition blue + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory black/red + ignition harness
Second Accessory black/white + ignition harness
Third Accessory
Keysense white/blue + ign harn or BCM, 16 pin plug, pin 4P
Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors. The BCM (Body Control Module) is in the driver kick panel.
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock lt. green - BCM, 24 pin plug, pin 7M
Lock is negative trigger thru a 1000 ohm resistor. Unlock is a straight negative trigger. MUST use relays. The BCM (Body Control Module) is in the driver kick panel.
Power Unlock same as power lock wire
Lock Motor red/blue 5wi BCM, 8 pin plug, pin 6B
Driver Unlock Motor red/green 5wi BCM, 8 pin plug, pin 6G
Passenger Unlock Motor red/black 5wi BCM, 8 pin plug, pin 6A
Parking Lights (-) red/white - headlight switch
Parking Lights (+) lt. green/black + BCM, 12 pin plug, pin 9K
Hazards blue/orange - switch or BCM, 16 pin plug, pin 4G
Turn Signal (Left) green/orange + BCM, 16 pin plug, pin 2K
Turn Signal (Right) green/white + BCM, 16 pin plug, pin 2I
Headlight blue/green - headlight switch
AutoLights
Reverse Light red/yellow + BCM, 16 pin plug, pin 8P
Left Front Door Trigger green/orange - BCM, 16 pin plug, pin 1F
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision yellow/black - BCM, 16 pin plug, pin 1I
Trunk/Hatch Pin brown - BCM, 16 pin plug, pin 2F
Rear Glass Pin
Hood Pin gray/red - pin sw or BCM, 16 pin plug, pin 8M
Trunk/Hatch Release yellow - switch or BCM, 6 pin plug, pin 5F
The BCM (Body Control Module) is in the driver kick panel. The trunk release motor wire is blue (+) in the driver kick, harness to rear.
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left) N/A
Power Sliding Door (Right)
Factory Alarm Arm blue or blue/white - BCM, 24 pin plug, pin 7J
Meter this wire while turning the key in the driver door key cylinder. Arm is negative trigger thru a 1000 ohm resistor. Disarm is a straight negative trigger. MUST use relays. The BCM (Body Control Module) is in the driver kick panel.
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock use key sense wire
Trunk Alarm Shunt
Tachometer NOT green/stripe ac any fuel injector
Wait to Start N/A
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense green/red ac radio or BCM, 16 pin plug, pin 4H
Brake Wire green/yellow + switch or BCM, 8 pin plug, pin 6J
Parking Brake brown - parking brake switch
Horn Trigger purple/white - switch or BCM, 16 pin plug, pin 4F
Wipers gray (L), yellow/red (H) + windshield wiper switch
Left Front Window (Up/Down) red - green A driver window switch in door
Right Front Window (Up/Down) red - green A passenger window switch in door
Left Rear Window (Up/Down) red/yellow - yellow A driver kick, door harness
On the MAZDASPEED6 models, the LR window up/dn wires are red - green at the left rear window switch in the door.
Right Rear Window (Up/Down) red/white - brown A
Thanks for the help man. I tried calling a few garages but no one would install a remote start on a manual transmission.
Any shop that has alldata should be able to find the neutral saftey wire on the MS6, if they hook it up the RS will not attempt to start the car when it is in gear. It is perfectly safe when hooked up properly..
I just noticed the tech sheet doesn't list the neutral saftey wire for you, I'll check at work tommorrow and post it for you..
Or get a new Directed model. IE: Viper 5101, 5301, or 5701. They are actually set up for manual trans. OR, bypass the clutch. My honest opinion, if you havnt done it before, let someone else do it. You dont want to mess up your transponder or your car will be dead in the water. You also CANT TEST the RX/TX wires you need for the bypass with a DMM.
My input is to leave it to the pros...electrical stuff is always dangerous in my opinion. But let us know how it works out man.
