reg. 3 & ms3
SPEEDYHANS
speed 3 (mS3)
guy i need some help i want to know if the suspension for a reg.3 is the same as a speed 3 whats deferent whats changes will a coilover system for the 3 work on a speed 3 will it not work. i want to know if u guys have other different coilover instead of the BC which is the only one i see that out there plxz help(hear ya)
hehe are you looking at the cheaper ones on ebay? if so I was thinking the same thing, if the ones for a regular 3 would work on the mazdaspeed 3
does the 3 have a macpherson setup all around? because the speed3 has independent rear suspension i believe.
Yes they will work on the Speed 3. Make sure you find out the spring rates before you make your decision. The reguler 3 setups may have lower spring rates when compared to Speed 3 specific kits.
