So I decided to open another thread since I have a better idea of what's going on now. Here's what happened. I changed the passenger side mount and than the front mount. The vibration was still there. I placed a floor jack underneath the transmission and lifted it a little and the vibration went away completely.The trans was leaning on the subframe bar(not sure what to call it, the frount mount is bolted onto it) I figured it was definately that mount on the trans on the driver side next to the battery. I take it out and it's a little messed up so I have a good feeling this will finally be the end of all this. I put in the new one and its just as bad. So basically all the mounts but the rear one have been changed. The reason for the vibration is the trans leaning on the subframe connector. Is there anything else that would cause that or is it definately that rear motor mount. It looks like a PITA to change so if anyone has any other ideas i can try first I'd appreciate it. Thanks a lot
