Rear hatch glass shattered suddenly for no reason
Based on my experience with this window in the rear hatch, and evaluating the build/design I come to the conclusion there is insufficient cushioning on the rear hatch of the latest gens of mid size SUV’s. The prior gens had a split system and the ability to lift the window portion independent of the tailgate, and were well cushioned with rubber seals. The latest versions are all single tailgate/window incorporated into 1 module and the window portions do not have a cushioning seal surrounding the framework. Result? Vibration, and solid type of impact around the perimeter of the glass which encourages micro-cracking and eventual failure.
Just my opinion, but the manufacturers can and will, as in my case with Mazda Canada, deny, deny, deny. In fact Mazda CA indicated to me they had never heard of the issue despite it being well documented throughout the internet.
I also registered my issue with the Canada Transportation Safety Board for an investigation of Mazda and other manufactures denial of their being aware this is a problom and the failures that have ocurred. Hopefully they can also pursue my suggestion that they concert with the US DOT.
... The prior gens had a split system and the ability to lift the window portion independent of the tailgate, and were well cushioned with rubber seals. The latest versions are all single tailgate/window incorporated into 1 module and the window portions do not have a cushioning seal surrounding the framework. ...
Are you talking about Mazda CX 5's or are you saying SUV's in general? I don't recall the CX5 rear hatch window ever opening independently of the hatch.
Those were basically trucks with a permanent topper and 2-3 rows.
These Crossover Utility Vehicles are just bigger cars.
There are still some "SUV's" on the road, like the Suburban.
It seems to be really random IMHO. I had '19 and '21 CX-5s and drove them for a total of 57k miles. Never had an issue. I see this issue on the forum from time to time, but it doesn't seem to be a rampant problem in the CX-5 anyway (otherwise there wouldn't be such long gaps between posts...). It's just bad luck when it happens to someone.
