rear creaking. HELP!
djza2u1
08 Black MS3
Just reciently i started hearing creaking from my rear end (hold the jokes). I think it is the sway bar sense i changed to the cobb sway bars about 9 months ago. I greased them with 2 different kinds of grease and still. I have AWR endlinks and i lubed them up too. And still there i cannot figure it out.
It happens when i go over uneven areas or bumps. Please chime in on what you think it could be.
I know the feeling dude. Had a creaking today and spent two hours trying to solve it. Turned out to be shock related since I just installed my BC's. Try and tighten every bolt you can find. That was my issue. I had one loose bolt that made the whole car sound like it was going to fall apart.
Fixed. I had to take the bushings out and grease the s*** out of them inside and out. Adjusted and tightened the clamps. All good now. I hope i dont have issues with the front one, bc it was a pain in the ass putting in.
