Really strange noise while driving
Hey all, I'm new to the forum and mainly joined due to the fact that I'm having trouble diagnosing a strange noise coming from our 2017 Mazda CX-5 AWD Grand Touring. The car is my wife's daily driver, and it has about 103k miles.
We replaced the tires about 2 months ago with the same Toyo tires as what comes stock on the vehicle.
My first thought with this noise is that it's being caused by a wheel bearing. The noise started as a humming noise, and has escalated to what you hear in the attached video. This video was taken from the driver's seat while driving about 55mph down the highway. The noise goes up in volume the faster the vehicle goes. It can be heard just about any time the vehicle is moving. It does become hard to hear past 65mph, but I assume that's mostly due to road noise.
I typically do all maintenance and repairs on our vehicles, but I've been pressed for time recently due to work. So I had my wife take it to Firestone for a diagnostic. They said they ruled out wheel bearings and CV axles, and recommended we take it to a dealer for a better diagnostic. I still have yet to be able to check it out for myself. I'm really hoping it's not a bearing in the transmission, but I'm not sure what else it could be if Firestone is correct.
I'd appreciate any thoughts. Thank you!
Sure sounds like something in the driveline. Have you checked fluids in transmission, transfer case and rear differential?
It sounds like an expensive noise. 😕
I appreciate the reply. I'm going to make time today and do a run through of those. I can't imagine it being the transmission as it still shifts really smooth. My mind has been on the transfer case (front differential, technically right?), so we'll see what we find.
I assume you checked the simple stuff (the KISS principle)? To me it sounds like something is rubbing, perhaps against the splash shield for the brakes? Something may have accidentally gotten bent when the new tires were installed.
If it started immediately after the new tires were installed, I'd take it straight back to the tire shop and ask them to fix it. I agree that it's probably something rubbing against a tire. Perhaps a loose fender liner or plastic front shock cover.
Can you pinpoint front or rear and which side? Sounds like a wheel bearing I just replaced on my G35x. Do you notice the noise changing going into corners at speed?
Is it fairly consistent at speed regardless of the pavement surface condition and age?
One more vote to check for rubbing. I had a scraping noise, turns out the brake shoe was slightly bent and making contact with the rotor intermittently. In your case, the sound is more like a grinding type of sound. If you can localize the sound to one side or corner of the car, perhaps by standing outside while someone else drives the car past you, it may make it easier to narrow down the scope of your inspection.
Definitely this is something worth checking, if it's a "grinding" or "scraping" type sound.
I once had a tougher stick get lodged in the braking assembly, on one corner. Made a hideous sound (more grinding/rubbing than screeching), intermittently, mostly while driving more slowly, more-frequently when also turning.
You never know, with these sorts of things.
Look up "chassis ears" or "chassis stethoscope" and get one. Basically they have like 6 or so little clamps that detect noise, you clamp them on to a part near where you suspect the noise is coming from and go for a drive. Then the little receiver will show you which area is loudest. Very helpful for trying to narrow down where noises are coming from.
I appreciate all the advice, everyone. I finally had enough time to get some great looks today.
Didn't notice any rubbing or grinding anywhere visibly. I pulled the transmission fluid dipstick and the fluid looked good--not great, but not bad at all.
Then I looked at the front differential fluid, and did a drain and fill. The fluid coming out still looked really clean, and the fluid still looked pretty light in color.
Then I got to the rear... Completely dry, and I pulled out quite a bit of magnetic chunks with my magnet. I'm assuming it was dry due to the heat, and tbh I blame myself for the neglect on my part. Lesson learned, and hopefully a lesson to everyone to do those flushes more often. They're incredibly easy to do when you have the right tools.
... Then I got to the rear... Completely dry ...
Ope! I guess that's the least bad of three places (trans/transfer/rear diff) to find a problem.
I 🤔 wonder where the fluid went for it to be dry? Any signs of wetness around the differential? I imagine if it was dry, you'll be able to see where it's coming out soon with a fresh fill on it.
Glad you found the source of the noise and hopefully before much damage was done.
Unfortunately, I believe this differential has served its time.
I think the oil got really hot due to the broken gears and just baked until it was solid/dissolved. That's my best guess other than a leak. I don't see any signs of leaking anywhere, although the rear obviously gets dirtier than the front
Bummer. If you replace it yourself, I believe there will be some control box work to be done afterwards to make the new unit play nice.
I really appreciate this advice, as I would've had no idea.
Now I'm wondering if I can do this with Forscan.
Maybe the PC based version (not lite) could. 🤔 If not, maybe it wouldn't be too much to have a Mazda dealer wrangle the 1's and 0's in line for ya.
That's what I'm thinking. Most of the information I'm seeing in programming involve buying a $100+ OBD module. I'd rather just pay the dealer that much to program it.
Well, once you have the dongle, you may not have to pay the dealer ever again. :)
Similar Threads and Articles
