yellowprotege5
they just dont feel right and i keep grinding them. what do i do? add transmission fluid?
Butlerg said:Is that what is possibly happening to me? When I go from 2nd to 3rd I hear what sounds like a quick grind/grating/clunk sound. It only happens in 2nd to 3rd though. I literally have to start to bring the clutch out slowly and a inch or so and slowly move the shifter to thrid in a zig-zag pattern (sort of) while bringin the clutch out...I already changed the fluid to synthetic about 10,000 miles ago to.
what is double clutching?P5inder said:There is a TSB out there for third gear Synchromesh being weak and needing replacement on pre 2003 vehicles, IIRC.
My 2002 grinds into 3rd each and every time I shift trying to maintain the proper RMP... It really grinds when trying to shift quickly into the gear.
This transmission really doesn't like quick, efficient shifts...especially 2nd and third gears. I have since started double clutching and although it works most of the time, sometimes I still have to wait until the revs are waaaay down before I can shift into 3rd gear without grinding.
I really miss my Neon's transmision...never missed a shift, never ground it, power-shifting that tranny (omg) was a great feeling...nothing better than awesome, quick shifts.
newprot5fan said:I took mine in to get it checked. Mine grinds into second and sometimes won't go into third. THe dealer is replacing synchros, shift forks, .etc..etc...still under the power train warranty....there is a TSB for a hard shift into third......maybe take that to your dealer if you are having a tough time with third as well...
TreFlip999 said:what is double clutching?
there's a million and a half threads dealin w/ thatMTV said:How can you tell when your car was produced? For example if I wanna find out if mine is an 02.5...
Matt
Matt
