im going to be getting a different amp and sub eventually ... what could i use the stock amp for? should i run the front speakers off the amp?or should i just ditch it entirely?
It's a full range amp, so you could use it again to power your stock MSP fronts. It'll give them 40W...you can use the crossover on the stock HU, because I don't think the Kenwood's will work as a high pass, but I forget...it might! Either way...it'll work for those Kenwoods right up to some mid-range components if you decide to replace them.
