Re-mounting door panel trim
I recently replaced the speakers in the front doors and now I'm not sure that I have re mounted the door panels correctly.
There is a weather strip about 50 cm long that mounts up against the inside window and the top door trim.
When remounting the door, I slid it onto the door trim, and when fitting the panel had to slot it onto the door while folding the bottom of the panel out and then click the panel on. It was quite hard, and I'm wondering if that was the correct way to do it?
Also, when I hit speeds of about 90KM I start to notice a bit of wind noise, and wondering if it is because of the weather stip not fitted correctly, the outside mirror or the roof racks. I just can't remeber the wind noise from new as I replaced the speakers about a week after buying the car.
Cheers
I remember when I did mine, seeing a post saying you should put the loose weatherstrip/trim on the DOOR first, then push the inner door panel into it. Worked fine that way for me and was easy to get the panel on.
