RCA Jacks on the subwoofer?
jsesq
There are 2 sets of inputs (female) RCA connectors on the subwoofer.
I had to disconnect my sub today and when I was reconnecting I saw that one set was "input" and one was "output", but I couldn't tell a difference in sound if I hooked the plugs (male) into one set or the other.
I admit that I am not a mobile audio expert, but which set should they be plugged into? I doubt that it makes no differerence. And finally, where are those plugs going?
Your wires should go into the INPUTS. The outputs are a pass through in cas you want to add another sub or amp. I would think it would make some difference in the sound, but maybe not. Still I recommend using the inputs.
Good luck.
:cool:
