zverg said:I wish I had ordered replacement front endlinks when I ordered my MSP rear endlinks. I guarantee I'll break both front endlinks when installing my struts this weekend. I'm not about to wait on the endlinks before doing my strut install.
ke20sprinter said:Soak it with WD40 for a while & take out the endlinks before you remove the struts...That way the endlink is being held down with the swaybar and it shouldn't move (this is what I did).
InFeXIoN said:alrite, the MSP/Mp3 endlinks are about an inch longer than Regular protege's and p5's stock endlinkes. So yes you need them. After you get those, u will be fine. All i had were MSP horshoe brackets, Mp3 bushings and Mp3 endlinks.
Went on perfectly.
InFeXIoN said:Well, we'll see. All i know its what i got to make it work perfectly without any problems, Only reason i have mp3 bushings from mazda is because i was in a bind at the time, but will be switching to AWR's replacement 20mm's as soon as i start to hear clunking which hasnt happend yet.
I nearly fell off my chair when I saw your sig...really funny (rlaugh)aMaff said:we changed the spring's on Foolish's car this weekend, and to get the endlinks off of the strut, we sprayed it down w/ some PB Blaster and then used a wratchet w/ a pipe (the handle from my raching jack lol) to break it loose. It worked better than I thought it would lol
neoturner said:So how bid a difference do aftermarket swaybars make? is it worth it on a daily driver (with a little boost to boot) Thinking about this in the future once i get used to how the blues feel, but if it's marginal I may just go without.
