Random Misfire
Schwamm
2003 Mazdaspeed Protege, 2008 Mazda 3 Hatchback, 1984 RX7 GSL-SE
My engine is randomly misfiring (P0300), and I've replaced spark plugs to start with. I'm not sure if the root of the problem is a coil pack or spark plug wires somewhere, and I've only been able to test the two wires under the coil packs with a new part and that didn't fix the problem. Before I go spend money on different wires or a coil pack, has anyone had this happen to them or know what caused this, or would most likely cause this? Any easy way to test? I've heard I can use an ohm meter but I'm not sure exactly how.
my car was doing the same thing and everyone told me to replace the coil packs, so I did and it runs and idles good now, so I would try that first its not too expensive, I think you can get them at Auto Zone for around 26.00$ a piece, Good luck
Bumping this thread - what would cause repeated coil pack failures?
I'm on my second set (including plugs & wires) in 6 months and the car is acting sketchy again like this set is going bad too.
For ref - I've got catless midpipe, corksport dp, hard intercooler pipes, (recently replaced) mbc at 9psi & AFC on stock supermap.
I DO think I've got a boost leak so I'm checking into that. I cleaned the EGR probably 10k miles ago.
