Read below to learn how to:
Properly Lock the Primary & Secondary shafts for removing/installing the lock nuts
Part Number for Oil Pass (also known as Oil Guide or Oil Funnel that goes from Transaxle case to 5th/reverse cover)
One trick to pressing in your new Axle Oil seals
I apologize if this has been answered somewhere, but after several days of searching & reading page after page of threads, I haven't found any answers.
How do you properly secure the primary & secondary shafts from turning while torquing down the lock nuts? I rigged up a method that involved a crescent wrench on one of the nuts and braced to the table while torquing the other, however it was a pain in the a$$ to secure the transmission properly to the workbench and afterwards it tipped over & broke the damn oil guide for the 5th/reverse gears. :mad:
Is there a better way to keep the shafts from rotating while torquing these nuts?
Thanks so much for all of the help!!
