Question on max cargo weight load
Neuron
2013 CX-9 Grand Touring AWD w/tech. package
Hi!
Can anyone tell me what is the maximum allowable cargo weight load in lb (with 3rd row seats down) in 2013-15 CX-9?
I can find only data on towing capacity but not on cargo weight load.
Thanks so much in advance!
It sounds like you're trying to find the GAWR (Gross Axle Weight Rating), which the is the maximum allowable weight that can be carried by a single axle (front or rear). Am I right?
These numbers are shown on the Safety Compliance Certification Label located on the driver's door frame or door pillar. The total load on each axle must never exceed its GAWR.
You can find more info in your owner's manual. Do you have one? https://www.mymazda.com/MusaWeb/pdf/manuals/2013_CX9_OM.pdf (you have to log in to see the file)
Thank you LeilaniRL!
You may be right and yes, I do have manual. I'll take a look.
Thanks again!
Thanks again!
It's not in the manual. They print one manual for every vehicle. Like she said, you need to look on the certification label on the driver's door frame. That specs on that label are all based on the exact equipment your specific CX-9 has.
Yes. I saw what she said and I'll look on the certification label on the driver's door frame as first.
Thank you.
New Threads
