Alright, I've read the thread by LinuxRacr where he says to use the pink wire with the blue stripe (#60 on the ECU) for installing this gauge inside the car.
I pulled my MSP apart, found thiswire, and I wanted to verify that it is the correct one.
There is already another wire spliced into this one.
When running the car, my voltmeter reads 0 when connected to this wire (bare spot).
Should it not read between 0 and 1V while the car runs? Fluctuating?
I want to make sure this is the correct wire before hacking it to tiny pieces.
Those of you (with MSP's) that have installed an A/F ratio gauge, and wired it INSIDE the car (not through the firewall), where did you tap into??
Thanks for the help!
