Question about key fob (and surfing)
solution
Ok so I have a fix...
I used this on my old car....
surflock.com.au
(there are many similar products in the US.
It just fits the entire fob, without having to remove the key.
I though if it were locked in this at the rear of the car (i have mine secured to the tow bar) it would be too close and activate keyless entry...turns out its just far enough away from the receiver to work.
Problem solved.
surflock.com.au
Problem solved.
Edit
This doesn't work - hatch will still open.
Remove the key from the fob, put in glovebox, lock car manually with key and put key in surflock - works.
