96 2.5 V6 - 131k .sorry for another one of these questions but i have read quiet a bit and would like confirmation. recently i noticed a knock at about 2300 - 2400 rpms. it is most audible near the timing cover/intake. my first thought was hla but they sound normal at idol. now i am thinking it is the timing belt tensioner but it is hard to tell. what has me confused is the knock gets quieter past 2400 and there is no noise at idol. the guy i bought the car from said he just replaced the timing belt ( old one was in the trunk ) and head gaskets. he did not replace the intake gasket ( it has a bad vacuum leak ) or the valve cover gaskets. this has me thinking that he probably didn't replace the other timing components either. is this normal for a bad tensioner or do you think i have a bad hla? i would think if it is a hla that it would be noisy from idol to high rpm or clear up some of the time. the car needs a knock sensor so my plan is to replace the intake gasket and valve cover gaskets when i install the sensor. should i go ahead and remove the timing cover and check/replace the tensioner ? i guess i should so i know weather or not to replace hlas. whats your opinion? i have heard the hlas can be rebuilt , what does this consist of ? i plan to keep this car for a while but i don't have a great deal of money but will borrow it to make sure it is right. thanks all for any help/advise/opinions.
