Putting 2nd sub in?
KurtMP3
Im getting a second sub, i identical and with the same wiring as the one already in there by Kenwood...Im assuming it will be easy to just wire up the 2nd sub since its already made and set to work with the system...am I right in assuming this?
But...
You will be drawing double the power through the already wimpy power wires.
You may want to look into a bigger power wire.
