Pulleys from srmotorsports.com
ok i will be getting them done and dynoed tomorrow morning so i will post all new stuff tomorrow night!!!
Make sure they know what they are doing and that the engine is a DTC at all times when removing that pulley. And also make sure they tighten it up properly.
There is also a note that the pulley bolt needs to be replaced after it is removed. You might want to look into that too.
thats says it applies only to manual models...if i read the right one..i think i did
It says "workshop manual" so yes you read it wrong. Besides it is the same part for both the manual and the auto 2.0L and 2.3L
that was thrown around the focus forums as well for safety sake. the 2 local guys didn't choose to go that route. it was said to make sure the engine (bolt) is completely cooled down before doing the change, as when at temp the bolt can tend to stip due to the high tq spec on them. i believe my manual says ~75lbs and then another ~90deg turn. if you don't go with the new bolt, make sure the engine is cooled down well to be safe.
i will tell them that but im pretty sure they would take every precaution
I think you mean TDC, which is the acronym for Top Dead Center.
DTC is the acronym for Diagnostic Trouble Code.
ok so i got them put in...but unfortunatley the dyno guy was off today so igotta wait til next tuesday to do it....but i do feel a big difference in the 4000-5000rpm range. once i get it dynoed i will post the results!
how long, and how much was the install? (assuming you paid for it) and good luck with it man... very interested in the dyno results...
Pulleys don't have anything to do with valve timing. The only thing that can be affected is ignition timing.
well they charge $60 an hour and i paid $80...so 1hr 20min, yea i most def will post the info
Like ****... By Swapping the "Timing" you are adjusting when the lobes open the valves...
tsunami said:
(bump) for dyno update information.... or somethin....
hey sorry i am getting the dyno done this week...the other guy that i had do my 1st one hasn't called me back or anything so **** him but yea as soon as i get the chance this week i will post it up...sorry...they are doing great though!!
