Protege5 starter is 8T or 10T?
JazzySP20
Madaz
AUSTRALIA
BJII Astina SP20
Is the P5 2.0 FSDE 5 speed starter 10 tooth or 8?
Searching the internet gives me conflicting results. A 100% positive answer would be appreciated.
10 tooth manual, 8 tooth automatic
Mitsubishi # M000T80381 (manual) or M000T82281 (automatic)
Thanks Theman. Did a search and everything comes up as the **0381 is for 1.8 FPDE. Looked on eBay and **0381 is listed for 'ASTINA 1998 - 2003 BJ 1.8 FP MANUAL 09/98-12/03' :( No 2.0 FSDE listed.
http://www.ebay.com.au/itm/MAZDA-32...UAL-09-98-12-03-FP13-M000T80381-/201352085477
Either way, I'll be replacing the starter very soon and looking to replace it with the 1.4kw version that was apparently fitted to earlier Mazda's. The only info I have is that the 1.4kw starter is 207mm long (standard P5 is 194mm).
Do you know which models of Mazda had the 1.4kw starter TheMan? And the OE part #? I'll be looking at getting a Bosch equivalent.
