i just bought a 03 protege5 auto
and i only get 24mpg hyway, is this normal?
i though i should get aroud 30
Not normal. Well, not normal unless you were driving 90mph the whole time, or driving into a headwind.
Since it is a new (to you) car the problem could be a lot of different things. In no particular order:
1. Check for CEL codes
2. Check plugs (might as well just replace them)
3. Check air filter (ditto)
4. Check oil (if not brand new looking change it and the filter)
5. Check transmission fluid.
6. Check for dragging brakes
7. Check compression.
Is it running rough? If so
8. Consider replacing the two spark plug wires
9. Consider replacing the two coils.
[Do not buy either of these at a dealer, shop around for a (much) better price.]
Is it running really, really rough? If so
10. Search this forum for "EGR" and read up on that issue.
