speed1016 said:Cool, sorry I didnt get back busy day. So how much boost are you running? Glad it worked out.
im finding that it's near impossible to perfectly tune this thing...Stormtrooper77 said:s***! Does this thing ever take forever to tune?!?! I think I've done about 70 km's worth of runs and it's still iffy.
my limiter doesnt activate until .5 psi past what i set it at... so if you want it to start limiting you at 8psi... set it to about 75 or 76... it'll activate at 8psiStormtrooper77 said:Okay, so with my settings above, how come sometimes the unit beeps and turns red on me? I have the warning set at 8 psi but under boost I never see the gauge hit that. The only thing is the peak boost level reads 8.1 - 8.3. Is this not boost spike? I'm just wondering why that it beeps sometimes and sometimes it doesn't and peak boost level is always in that range?
Your Gain is too high.Stormtrooper77 said:All the plugs are out for me.
Stormtrooper77 said:msp4you: What are your mods?
my profec in PSI reads identical to my apexi mechanical gauge... they are both fed from the same sourcemsp4you said:Rumor has been told that the PSI setting on the Profec Spec 2 is incorrect so I would recommend switching back to the BAR reading to see if this helps you guys out any.
