Procedure to Repair Center High-Mount/3rd Brake Light
2010 Mazda CX-9 Touring
I was wondering if any of you have the procedure to repair/replace the bulb.............or is it the whole light housing? I was able to successfully remove the interior trim cover by carefully prying it with my fingers. I disconnected the lamp cord (part TD11-51-571B) from one end but am struggling to pull out the socket from the light housing. I pressed on both sides of the socket to compress the two small plastic retarders and tried pulling it out to to luck. However, the socket can go in further if pushed with the plastic pieces on the side compressed. I still do not know whether I am on the right path. Thanks in advance for saving me a trip to the dealer.
