Did you try this as per The Mans suggestion?Benfolio said:Sounds like someone had some Jiffy Pop under the leading edge of the dash. POP POP, POP POP POP.
as for the popping noise, there has been issues with the mazda3s making that same noise... it's really annoying and sounds like it's coming from the corner of the windshield by the dash but at the same time it sounds like its from the outside, it's REALLY weird... cause of the problem is due to the cowl panel bolts not tight enough... when you open the hood, you'll see this big black piece of metal that runs at the top of the firewall under the plastic cowl/wipers.... there should be ONE bolt next to the strut tower, those have been the problem causer on the 3s, go ahead and LOOSEN the bolt first then retighten them... get them a tiny bit tighter than usual, but becareful not to break them! do that on both sides of the car
Dude: Can you send a copy of this or a link etc. Thanks much.Benfolio said:p.s.
As of yesterday there is now a TSB for the suspension squeaks/noise. Covers all four sway bar bushings, and all four control arm bushings. Depending on where the noise is found to be coming from.
FINALLY.
afticarab said:Dude: Can you send a copy of this or a link etc. Thanks much.
Thanks: My local service manager will have it in his email Monday AM. Any TSB on the sliding door lock freezing.Benfolio said:See if this works..... http://www.mstore2000.com/PDF_Files/02-007-06-1675.pdf
Cool. Thanks for sharing.Benfolio said:See if this works..... http://www.mstore2000.com/PDF_Files/02-007-06-1675.pdf
olddaddy said:Does this mean that vehicles made after 1/27/06 shouldnt have this problem or this fix is only for vehicles made prior to 1/27/06?
I know I already mentioned this, but relating to this particular topic, my 2007 Mz5 was made in about August 06 and I've yet to hear the sound. That's not to say it couldn't be planning a surprise attack in the heart of January, though.We&2kids said:It does say on the service bulletin that:
To stop the noise, the following mass production changes have occured.
- The shape of the front lower arms along with the attached bushings has been changed.
- The stabilizer bar bushing rubber was made harder and the amount of wax that is included in the front/
rear stabilizer bushing has been increased.
So hopefully all productions after 1/27/06 won't have the problem. We will see....
Well ours was manufactured in April 2006 and has the "crunch". (pissed)We&2kids said:It does say on the service bulletin that:
2cam16 said:Well ours was manufactured in April 2006 and has the "crunch". (pissed)
