Problems with my belts
i took of the belt for the compressor and left on the water pump belt and its the water pump belt that causes the noise also i'm running gatorback belts
looks like you may have found the culprit then. maybe try to grease it up some before you replace it. luckily waterpumps arent that expensive as say the ac compressor which is my current issue.
I heard that gatorback belts squeek themselves.. it could also be the alignment of your new water pump.. doesnt take much to throw s*** off.
