problems with my bearings for b2200
I have a 1990 b2200 and as of yesterday everything was going good, and now my rear end has seized up...I was wondering if anyone knew if the rear wheel bearings are sealed? My haines barely touches on the rear bearings...
I thought it might be my diff, but I changed the oil out like 2 weeks ago, and everything was fine. The haines manual says to remove the rear axle shaft and have the bearings pulled by a mechanic and then press fitted witrh a hydraulic press....is this the only way or does someone know a way I can fix this myself? Any thoughts would be greatly appreciated....
