Problem with the front of a mazda 626
Has anyone had a problem with their mazda vibrating and shuddering on a certain speed. because my car is showing these things and I was wondering if someone is experienced with these problems. I have already put new drive shafts and its still shudderring, mainly between 20 to 40 km on second gear and its a manual car. If anyone can help and know what this problem might be, i would be glad for someone to tell me even if you are just assuming.
thankyou, bye.
alignment? i hope you would check that before replacing drive shafts...
moved to correct (i think this is the correct section??) section as well.
mine would shake badly at about 60 mph. it was outer tie rods. check the whells when they are off the ground and check they tie rods and the ball joints. move the tire side to side and top and bottom and see if it moves. it shouldnt move
