J jal142 : Former owner of a 2010 CX-9 GT Sep 18, 2020 #2 Scored main/rod bearings? Unfortunately, by the time any codes are thrown the oil has been contaminated for a while. What codes were thrown?
E erhayes 2025 CX-5 Turbo Contributor Sep 19, 2020 #4 Interference engine. Hope the resistance wasn't valves on piston. Ed
X XclimberX : 2007 MS3 GT Sep 19, 2020 #5 It was definitely the pump gear. I scoped the upper motor and dropped the pan. Everything looks good. It wasn’t a hard stop and not metal on metal. Tension at the crank aligned with tension in the water pump gear.
