Pro5 Headlight Swap
As some of u know I work for Mazda and was curious to know if anyone thought of swapping the Pro5 headlights into the MSP....They look like they will fit with minor modifacations and with that at least u'll have a separate bulb for high and low beams...And u guys would be able to have an hid kit for the low without the worries of losing the high beam...just a thought. As I'm sittin hear at work bored staring at these cars.
the only mod reauired is wiring.
HID kits are now availabel with High/Low beams for H4 applications.
I know, I just don't trust the overall realiability of those kits.....I heard some bad things about them.
I-Am-Chris said:
I heard that the motor mechanism goes bad on the kits....either they get stuck in a position or end up not working at all after a lil while.....I'm only going by the stuff I hear....I have no personal experience with them though.
my dual beam HID's work just fine and have for the past 3 months. the car even sat for a month and the lights work fine. where did you see or hear this info?
Just browsing the different car forums, I remember reading it. I like the look of having 2 bulbs.
There is an H4 dual beam kit out there with NO MOVING PARTS!!!
It uses electronics to SHIFT the arc within the bulb, thereby changing the light pattern from low to hi beams...
www.autobulbsonline.com I think. I'll fix it if I find it's different.
In order to shift the output, there needs to be moving parts.
Our dual beam kits use a solenoid which pulls the capsule back and is spring loaded for return. The problems with the dual beam kits you are referring to are mostly the older retrofits that use a movable shield.... ours are of high quality and should not fail during the life of the capsule.
10% off coupon code MAZDAMP3 at http://www.liteswap.com
