If you plan on installing a modifed, larger turbo, you will want a tune for that. Simply put, running an OTS tune with the larger turbo can result in loss of power and or engine damage. You will basically NEED a tune for the turbo. In that sense, the tune is very much worth it and should be factored in as a cost of doing this modification.
Travis
COBB Tuning
