Power outlet doesn't turn off with car?
2010 CX-9 FWD Touring
The power outlet on the center console seems to turn off with the car, but whatever I leave plugged into the power outlet inside the center console arm rest will remain powered. Is this normal? Shouldn't turning off the car turn off all power outlets?
The one inside the console is always-on, I think.
Why not? Some are switched, others are constant.
Only the one on center console (on the right next to small box) will be on/off with ignition.
All others stay on all the time. Remember to unplug any high power device or you have to jump.
I forgot my cooler running all night and had to jump start in the morning.
Exactly what I'm trying to avoid.. Seems like a bad idea. If you wanted it on without the engine running, you should have to turn the ignition to accessory or something. But I don't see why anything should be able to draw power with the car completely off and locked.
