Does anyone know how to fix this symptom?
Power window with auto up/down driver side. When I down, goes down manually or powered. But when trying to bring it back up, ideally even if I let go it should continue going up. What's now happening is:
> Slower than usual starts to go up.
> Shudders while going up slowing and slowing to a stop.
> If I let go of the power button - goes down automatically.If I hold the button, after window stopped going up - remains fixed in place does not go up.
> Rinse and repeat this sequence few times - no effect, keeps going down when I release the button.
> The only way to do it is pulsing the switch. Little by little. Then after it crosses, i.e. going higher than the usual spot where it had stopped before, then it continues to go up - automatically.
I believe maybe something is stuck, grease/lubrication - maybe or maybe something serious and motor needs to be changed. When went to dealer, they said entire power module need to be replaced and quoted me $800 with labor. I jumped and disappeared from there.
Please help?
Please help?
	 . You get the drift. So, absent some erratic control module behavior somewhere (if there even is one) other than the electronics typically built into the drivers master control switch, it could be interplay between a failing window regulator and "safety stop" feature as described above.
