post up pix of your lowered protege!!!!
Goldlines on stock struts
awww man ur holding out on the lip how to. i know its garage door seal...i want to know how u put it on.
what rims are those?
16's right?
Close..but they are 15's
and redpro (whats your real name man so I can call you by it) but I just used some 3M double sided foam adhesive tape..and all around the areas that didnt have tape..like mostly the edges because you want to put the tape far back on the lip in order for it not to show from the front...i used glue like this
lol and I knew I should make a how to...time to bring out the camera.
JOsh. ur reals name is joel i guess?
i looked at it before. there several ways to put it on wheter u want it to hang, or to stick on there. but i like the way urs is. does it flap alot? i wonder if theres something u can spray on it to make it hard.
Joel is the name correct. And the material is actually quite stiff. You would think it would be all soft and flimsy but it is standing strong after scraping a few times so far.
lol @ nik. there is a spray ive heard of too.
J_noato, i want ur car
vel thats a nice P5. how is it annoying?
Joel, I shud go check it out again, but my time is limited before i go to school.
lol thanks. forgot to add the other info.
17x7 40mm offset w/ 5mm spacers
205/40/17 front
215/40/17 rear
rubs if i go over a big dip, but i'm getting the fenders rolled soon.
red99---> if i am alone its not much of a problem but once even one passenger gets in the car, left turns have a chance of rubbing, dips in the road also especially highway speeds
i have no rubbing. i just have to worry about the front bumpstops. kpsort cudnt get my main cylinder to move up. its pretty driveable though.
yall rub inthe front or the rear?
