- 99 protege
4X4! awesome
The kind that you use when your sway-bar is installed backwards...
What kind of links are these?
Lateral forces from the car, sure, but it affects the strut vertically Pushing from rear to front (or vice-versa) on a strut where the sway bar bracket is won't move the suspension at all (which is what the sway bar does). I'll take your word for it, but I've never seen a sway bar (that worked...) that had that much angle between the bar end and the strut / control arm mount because that's making it pretty ineffective. I can't find pics of mine, but I remember installing it, and I remember the end-link was fairly straight up / down. At an angle like that, you're killing the effectiveness of the bar. So... it doesn't look right, but ok.
Yeah, that's what it's supposed to look like. The endlink nearly perpendicular to the sway bar.
Yeah, but that wasn't my concern, only that the sway bar ends and the strut weren't anywhere near in alignment. The one in question has the end-link at like a 30* angle to the strut...iirc, the miatas sway bar ends are pointing toward the front of the car.
