Alright guys, just a general question that may turn out to be a stupid question, but I would like to know for peace of mind. I've been running my cobb stage v1.05 Stage 2+ TMIC + SF Intake 93 octane since last July, and the car has been behaving fine. The only problem I have, which may come from my exhaust set up, is in low rpms the car makes small popping noises from the exhaust. I have a turbo xs downpipe, into a turbo xs race pipe with magnaflow high flow cat, into a racing beat catback with main muffler removed and a 3" straight through magnaflow in its place. I don't know if this noise is normal, or I need to re-tune or I need to clean my maf out, etc.
Anyways, on to my question. When the weather changes from winter to spring/summer, do we need to re-tune/re-flash the car for that particular season, or is the AP setup to where once you flash it, it doesn't need to be re-flashed? Does this make sense? Like now that it is spring and A LOT warmer, does it make sense to re-flash the car the map its currently running for the warmer temperatures, or is the tune constant?
My power mods:
-turbo xs downpipe
-turbo xs race pipe with magnaflow HFC
-racing beat catback with dual chamber removed, magnaflow straight through in its place
-S.U. TMIC
-S.U. boost tubes
-medieval turbo inlet
-cobb SRI
-Turbo Smart S.U. by pass valve
-denso iridiums 1 step colder
-stock turbo/stock turbo manifold
Thanks!
My power mods:
-turbo xs downpipe
-S.U. TMIC
-S.U. boost tubes
-cobb SRI
Thanks!
