Poor Air Conditioning on MS3
RPI-Speed3
2007 Mazdaspeed 3, 2004 Mazda RX-8
Anyone that has an MS3 notice the air conditioning doesn't work that well unless you are driving around 50 or have the foot on the gas? This was a big issue with the RX-8 and the only fix was to wrap a bunch of heat shielding around the A/C return pipe to the cabin. Has anyone checked this out in the MS3? It seems that if you let the engine bay heat soak, the A/C goes to crap. This seems to be a Mazda problem as the Toyota's I've owned didn't have this issue.
mine was a little rough today when it was 102 degrees and i let it idle it in the driveway. but once i left the driveway it worked just fine for me
I was actually surprised at how quickly my air became cool just sitting after I started the car.
I had the same problem. When I took it to the dealer, they flushed the system and it's worked perfect ever since.
SPEED305 said:
no problem, i think its an isolated situation.
+1 I can hang meat in mine. Take it to the dealer and have them check it out. You may have a bad thermo-switch, but thats just a guess.
I have a similar problem. If im in stop and go traffic or just parked with the a/c on it blows warm air. If im moving in the highway gets nice and cold.
mine works great if its sitting in 90degree whether all day of course its going to take 5 or 10 minutes to get cold just like in a tub of cold water if you add hot water it has to reverse all the cold ....duh!
nypest , what your talking about doesnt sound normal it shouild work when idiling. I would take it to the dealer
