Pontiac unveils 2007 Solstice GXP
mikeyb
Contributor
01 BMW 325xi Touring
GM has released pictures of the Solstice GXP ahead of its debut at next week's Los Angeles Auto Show. The GXP is powered by GM's 2-liter turbocharged Ecotec inline four, good for 260 hp and 260 lb-ft of torque, making it the power leader in the Ecotec engine family. The new 4-valve per cylinder Ecotec turbo features direct injection (a first for GM North America) and piston oil spray cooling. Other features include 18-inch wheels, a limited slip differential, and a choice of 5-speed manual or automatic. 0-60 times are said to be less than 5.5 seconds. The GXP should appear in dealerships in the fall.
source:http://autoblog.com/2006/01/01/pontiac-unveils-solstice-gxp/
Solstice GXP
LOS ANGELES Pontiac s product resurgence zooms forward with the introduction of the 2007 Solstice GXP, the performance version of its in-demand Solstice roadster, at the Greater Los Angeles Auto Show.
The Solstice GXP pushes the production Solstice to the next level with a 47-percent boost in horsepower, and demonstrates how GM is working on all fronts to build and sell exciting products for diverse audiences, said Mark LaNeve, General Motors North America vice president of Vehicle Sales, Service and Marketing.
Solstice GXP features GMs all-new Ecotec 2.0-liter turbo, the most powerful production engine in the Ecotec family.* This turbo with direct injection kicks a V-6s worth of power out of a four-cylinder engine, an estimated 260 horsepower (194 kw) and 260 lb.-ft. (353 Nm) of torque.*
The performance roadster will feature GMs StabiliTrak four-channel electronic stability control system. It will debut in the summer and is expected to be priced about $4,000 to $5,000 above the base Solstice.
Solstice GXP will be on display with the Solstice, which features a powerful Ecotec 2.4L engine rated at 177 horsepower (132 kw) and is matched to a close-ratio five-speed manual transmission. The driver-oriented ****************pit interior features motorcycle-inspired instruments.
Turbo ECOTEC
PONTIAC , Mich. General Motors introduces the Ecotec 2.0-liter Turbo engine in the 2007 Pontiac Solstice GXP, making it GMs first direct injection offering in North America . Gasoline direct injection technology helps the Ecotec engine produce more power while maintaining the lower fuel consumption of a small displacement port-injected engine. It produces 260 horsepower (194 kW) and 260 lb.-ft. of torque (353 Nm),* making it GMs highest specific output engine ever, at 2.1 horsepower per cubic inch of displacement (130 hp / 97 kW per liter), and the most powerful production engine in the Ecotec family.
Variable valve timing and an intercooled, twin-scroll turbocharging system are used to optimize the Ecotec 2.0-liter Turbo engines performance. It was developed with the global resources of GM Powertrain in the United States and Europe , drawing on expertise from the naturally aspirated Ecotec 2.2-liter direct injection engine used in some European applications and the 2.0-liter turbocharged engines already in production.
With direct injection, fuel is delivered directly to the combustion chamber to create a more complete burn of the air/fuel mixture. Less fuel is required to produce the equivalent horsepower, especially at normal cruising speeds, of a conventional port-injection combustion system.
Direct injection technology works well with turbocharging and helps deliver a great balance of power and economy, said Ed Groff, assistant chief engineer, Ecotec 2.0-liter Turbo engine. The Ecotec 2.0-liter Turbo produces the power expected of a V-6, but in a smaller, more efficient package and the driving response is simply terrific.
A dual-scroll turbocharger with a lightweight turbine provides nearly instant power and an air-to-air intercooling system bolsters the turbos performance by reducing inlet temperatures. Dual cam phasing complements the turbocharging system by optimizing valve timing at lower rpm for best turbo response and quick engine torque build-up time.
The Ecotec 2.0-liter Turbo uses a stronger, Gen II Ecotec engine block, which was developed with input from racing experience to support increased horsepower and torque. The cylinder block bulkheads the areas where the main bearing caps are attached and the bore walls are enlarged for strength. Other areas of the engine were enhanced to reinforce the structure and the water jacket is deeper for added cooling capacity and improved cylinder bore roundness. This architecture is shared with the 2.4-liter Ecotec engine that debuted in the Pontiac Solstice roadster.
Highlights of the Ecotec 2.0-liter Turbo engine include:
  • Steel crankshaft
  • Forged connecting rods
  • Forged oil-galley pistons
  • Jet-spray piston cooling
  • 9.2:1 compression ratio
  • Aluminum cylinder head with sodium-filled exhaust valves
  • High-pressure engine-driven fuel pump
  • Variable pressure fuel rail
  • Dual-scroll turbocharger
Components including the steel crankshaft, forged connecting rods and forged pistons are high-strength items that provide strength and enhance durability. Jet-spray oil cooling directed toward an oil-galley piston help reduce piston temperatures. The system delivers pressurized oil to continuously lubricate and cool the pistons, which reduces friction and noise and ensures durability for the engines higher power levels. To enhance combustion, the piston tops feature a dish shape that deflects injected fuel toward the spark plugs.
To accommodate the direct injection system, the Ecotec 2.0-liter Turbo has a unique cylinder head and intake manifold. The cylinder head incorporates mounting locations for the fuel injectors which are typically mounted in the intake ports or intake manifold on port injection engines. A high-pressure fuel pump delivers fuel to a variable-pressure fuel rail. Fuel enters the combustion chamber through precision multi-hole fuel injectors. The fuel pump, fuel rail pressure, fuel injection timing, and injection duration are controlled by the engine control module. In this way, fuel is metered and delivered in a finely atomized spray.
Apart from the mounting positions of the fuel injectors, the cylinder head has conventional port and combustion chamber designs, although both are optimized for direct injection and high boost pressures. The sodium-filled exhaust valves and stainless steel exhaust manifold are durable components designed to stand up to the high-performance capability of the engine.
The unique cylinder head, fuel system, pistons, intake manifold, and the dual-scroll turbocharger are the only major components that differentiate the 2.0-liter Turbo from other members of the Ecotec engine family. Mobil 1 synthetic engine oil is installed at the factory. Synthetic oil was selected for its friction-reducing capabilities and high-temperature performance.
How direct injection works
Gasoline direct injection differs from the fuel delivery process of a conventional engine by delivering fuel directly into the combustion chamber, where it is mixed with air drawn in to the chamber. The combustion process of conventional fuel injected engines uses air and fuel that are mixed in the intake port or intake manifold prior to being introduced into the combustion chamber. Direct injection is a continuation of the evolutionary process of moving the fuel introduction point closer to the combustion location to improve control.
With the Ecotec 2.0-liter Turbo, fuel is introduced directly to the combustion chamber during the intake stroke. As the piston approaches top-dead center, the mixture is ignited by the spark plug, giving the name spark ignition direct injection (SIDI). The fuel injectors are located beneath the intake ports. SIDI allows the mixture to be leaner less fuel, more air at full power. SIDI also permits a slightly higher compression ratio than if the fuel were delivered with conventional fuel injection. The result is better fuel consumption at part and full throttle. The engine uses conventional spark plugs similar to other Ecotec engines.
A high-pressure, returnless fuel system is employed. It features a high-strength stainless steel fuel line that feeds a variable-pressure fuel rail. Direct injection requires higher fuel pressure than conventional fuel injected engines and an engine-driven high-pressure fuel pump is used to supply up to 1,276 psi (150 bar) of pressure. The system regulates lower fuel pressure at idle approximately 752 psi (50 bar) and higher pressure at wide-open throttle. The cam-driven high-pressure pumps works in conjunction with a conventional fuel tank-mounted supply pump.
Direct injections precise fuel delivery enables more complete combustion to help reduce emissions, particularly on cold starts the time when most engine emissions are typically created. Also, direct injection permits higher a compression ratio in the engine which is a positive influence on fuel economy. At certain power levels, the boosted SIDI engine can provide significant fuel economy benefits to the vehicle compared to a larger displacement naturally aspirated engine.
Turbocharging system
A unique, dual-scroll turbocharger is partnered with an air-to-air intercooling system to provide up to approximately 20 psi (1.25 bar) of power-enhancing boost. The dual-scroll turbocharger delivers nearly instant response, as dual exhaust passages from the engine to the turbine housing guide exhaust gas to the turbine. This reduces lag time, or spool-up, at low rpm.
There is virtually no lag with this system, said Groff. Throttle response is immediate. The engine acts like a larger displacement engine.
The turbocharger is matched to the engines displacement and performance objectives. It is supported by the air-to-air intercooling system, which uses fresh air drawn through a heat exchanger to reduce the temperature of the warmer compressed air forced through the intake system by the turbocharger. Inlet temperature is reduced by approximately 212 degrees (100 degrees C), enhancing performance because cooler air is denser and promotes optimal combustion.
Dual cam phasing
The camshafts of the Ecotec 2.0-liter Turbo engine have phasers that support the continuously variable intake and exhaust valve timing. They also have cam position sensors, so that the engine control module can accurately control valve timing. The crankshaft and camshaft position sensors are digital. A new engine controller, specific to the engine, is used to sense and control the engines performance parameters.
Variable intake and exhaust timing works synergistically with both the gasoline direct injection and turbocharging systems. The variable engine timing enabled by cam phasing allows the combustion process to be optimized. Also, valve overlap at low rpm can be adjusted by the controller to increase the response of the turbocharger, providing a more immediate feeling of power.
Ecotec family traits
The Ecotec 2.0-liter Turbo is built on a global platform that was designed at the outset for a range of performance and combustion capabilities. The Gen II block supports the high-performance demands of the engine, but it is merely a strengthened version of the original Ecotec architecture. The oil pump, for example, is the same as used in all other Ecotec engines. It was originally designed to support high-performance applications of future engines.
The 2.0-liter Turbo is the pinnacle of Ecotec performance to date, with additional growth planned. The groundwork for its capabilities was layed on the drawing table at the very beginning of the Ecotecs development, said Groff. Prior work and a far-thinking engine design continue to help GM respond to market demands around the globe more quickly and with greater accuracy.
This new Ecotec family member also has traits that have helped forge a reputation for durability and sophistication:
  • Dual overhead camshafts (DOHC) and four valves per cylinder
  • Twin counter-rotating balance shafts for operational smoothness
  • Electronic throttle control
  • Low-friction, roller-finger follower valvetrain with hydraulic lash adjusters
  • Low-maintenance chain-drive for the camshafts
  • 58X crankshaft positioning
  • Direct-mount accessories, which reduce or eliminate traditional sources of noise and vibration
  • Full-circle transmission mount to reduce noise and vibration
  • GM Oil Life System, which can reduce the frequency for oil changes
  • Innovative cast-in oil filter housing, which eliminates the need to crawl under the vehicle to perform oil changes and eliminates throwaway oil filter cans that retain used oil
As with other engines in the Ecotec family, the 2.0-liter Turbo engine also has premium features designed to ensure smooth and quiet operation, including a polymer coating and skirt design for the pistons that reduces noise during cold starts. An automatic hydraulic tensioner also is used to maintain optimal tension on the timing chain, which reduces noise and vibration.
<!-- / message -->
anarchistchiken said:
Oh goodie, I sense a Mazdasped MX5:)
Is it just me or does that steering wheel look just like a 3's?
I think it looks BMWish.
Is it me? or does the Solstice look like a car with down syndrome? The Sky is sucha seckier car. Would love to own the Sky Redline with the same engine.
Saw a couple of the '06 Solstices' on the road the other night.......kinda freaked me out, cause i had no idea what the hell it was. From a distance it looked like some sort of viper........but smaller. I had no idea these were already out........they look better than the mx-5's imo, much sportier.
That Pontiac is really neat looking, but strangly similar to the new MX-5. Saturn is coming out with a small roadster and BMW already has the Z3. It looks like everyone is trying to cash in on the MX-5 market. I have to say that the new MX-5 was a complete surprise. At first I didn't like the car, but after I saw it in person I was amazed! If I had the money I would take the MX-5 over the RX-8 (kinda sick for me). I did see one of those Solstices on the road a few days ago. I have to say that it does look REALLY GOOD......
the solstice is growing on me. i hope mazda doesn't wait 4 years to put out an MS version.
in this month's C&D, they had a story on Mallett (the Corvette tuner) and his 400hp, LS2-powered Solstice. apparently pretty much anything will fit in the engine bay; even the new Z06 engine.
The front end has a distinct BMW kidneys look to it with that black grill.
I love it, but I bet they still didn't fix the dumb things, one the 5 speed, or the gas tank that takes up all the trunk. Other than that I'd buy one.
I like the slightly tweaked look. Makes it look a little more purposeful.
Still dig the Sky more, though. I'm eagerly awaiting a "Redline" version of that.
03MzdSpdSTP said:
what problems?
These, one the 5 speed, or the gas tank that takes up all the trunk and the crappy top.
Don't get me wrong, I like the car but they really need to move that gas tank and give you some kind of trunk. And the back snaps on the top leave a big wrinkle. And every body (that has a sports car) has a six speed. It this car had one I bet the 0-60 would out do the mx5, just because of the tq. I wonder how much power the msp mx5 will have? I would be suprised to see a 250hp mx5. This is going to be a good War of the convertables soon.
nice. I love it. I also like the ecotec engine and this one seems really nice. wonder how much it could stand on OEM internals?
Is this the same engine thats in the TC?
TC engine is the 2.4L from the Camry. Its a toyota only engine.
Anyways that ecotec is probably built strong with all forged internals to make 130hp per liter.
No relation to the TC engine. This Ecotec should be able to handle a lot of power.
Steel crankshaft
Components including the steel crankshaft, forged connecting rods and forged pistons are high-strength items that provide strength and enhance durability. Jet-spray oil cooling directed toward an oil-galley piston help reduce piston temperatures. The system delivers pressurized oil to continuously lubricate and cool the pistons, which reduces friction and noise and ensures durability for the engine's higher power levels. To enhance combustion, the piston tops feature a dish shape that deflects injected fuel toward the spark plugs.
