Please Help, Unusual Power Window Problem
If someone could help me with this I would really appreciate it A LOT A LOT A LOT. I just bought a 2001 Mazda Protege ES about a month ago. The drivers power window didnt work. I figured that I am Mr. Fix It and that it would be an easy job to just replace the power window motor. So I got on Ebay and bought the entire regulator with the track and motor already complete. Then I read the forums to get an idea of how to complete the job.
WELL, here is where the BIG problem came in... I took of the door panel to see that the previous owner had does some unbelievable crazy wiring of his own!!! I see cut wires and wires that were burned and everything! So anyway, I replaced the regulator and put the new motor in and it has a wiring harness on it that has 5 wires. There are 3 small wires, red, black, and yellow, and there are two fatter wires which are the actual power wires. (I know this because I hooked up a positive and negative to them to see the track move)
ANYWAY, this is the problem. That wiring harness plugs in somewhere, and I dont have the plug that it plugs into anywhere! IF ANYBODY COULD PLEASE TELL ME THE COLORS OF THE 5 WIRES IN THAT WIRING HARNESS, I think I could figure out this MESS! It would save me a lot of money to fix it and not have to take my car to the STEALERSHIP! I just need the colors of those 5 wires in that wiring harness. If somone has a picture of it, that would be an even BIGGER HELP. Thank You all in advance even if you cant help me out. Curt.
hmm. i would think that the 2 big wires are to go to the switch, the black is to be grounded, yellow is to be the constant, and red is the switched. or vise versa
